i take upa with 93c56 * 16 is works
fab
Reading oki m951g as 93c56 does not work, I have tried with carprog in circuit, off circuit with elnec beeprog, batronix bx48 and genuine xprog.
All failed, exept elnec, but you need to select oki 16951
then SOP8 ( not SOP8x8).
U will see that the file read is shorter than a normal 93c56 bin file.
Hope that helps!
fab
oki m951g = 93c46
Use Upa and read like 93C56 16 bit.
i have solution for this ecu, if somebody need help, send me PM.
Hi m8s
Someone have solution/tested immo off for Nissan Terrano 2 "Bosch MSA15-24C02" solution.
Cheers
Press "THANKS" button. just one click, CHEERS
i need to disable immo in nissan terrano 2.7diesel ecu zexel
i tried a few dumps but without succes
thx in advance
Mark.
this ecu only with emulator
hello darling I search for nissan terrano immo off
I should just simply remove the OKI eeprom and it'll work?
[Quote = Okura; 2248769]. Tengo soluci?n para este ecu, si alguien necesita ayuda, env?eme PM [/ quote]
Good morning, I have sent a MP.
Thank you
[Quote = Okura; 2255018] esta ecu solamente con emulador
Saludos [/ quote]
Good morning. It's been more than a week (9 or 10 days) that I'm sending you emails to see if we can solve the problem of Terrano that I built the specific emulator that you sold me and I do not receive any response. I imagine it will be because maybe you are on vacation or for some justified reason, I would not like to think that it is because you do not want to take care of me since you have always attended me correctly.
Please contact me.
Thank you.
check PM message
I need help with this ecu. for immo off. You do it by file. emulator or just remove the eeprom starts the vehicle? Thank you
Enviado desde mi SM-N950F mediante Tapatalk
hi need immo off
Zexel 407913
