Results 1 to 4 of 4
    V.I.P. Member thered's Avatar
    Aug 2008
    Default Mondeo flywheel conversion question
    02 mondeo tdci estate
    got conversion kit under the impression it fits all tdci from 00-07 then noticed a bit of paper that says that for a 130 model it needs smaller teeth in fly wheel
    is that true??
    thing is i am a little unsure if this cars engine is original it may have been a 115 it was imported to the UK in 2007 ( originally MOD car) but it has no specific engine number on the log book it is blank
    any ideas on if they are all the same as in the advert i bought it it did say 130 and 115 i also gave reg and vin number
    be a pain stripping it down to find out
    ty
    Staffs UK
    true.
    The 130 with the 6 speed box always had problems if the solid flywheel conversion was fitted...... IT DON'T RUN!
    To compare the wheels without stripping use the scope and calculate the tooth/gap widths.
    Aug 2008
    mine is 5 speed does that make a difference is it one size fits all
    Aug 2008
    sorted they sent the wrong part i should have 5mm gap they sent 11
    car seems a little slower with the conversion kit is it normal??
    and it sometimes seems to give a little grind like the flywheels just out of sync are gearchanges expected to be a tad rougher ??
    ty
