Results 1 to 12 of 12
    Default fiat doblo 1900jtd fault codes
    hello to all mates......i have a doblo in my workshop with these fault codes........p1603 and p0254.....theb car start ok but dont accelarate.......i tried new battery for the first dtc but nothin...i mesaure the alternator and is ok....what can i check please???
    Is this a Lucas system?
    Then P1603 is a problem with 5V power supply for sensors.
    That could be a sensor drawing to much 5V or a wiring problem (short circuit) or the ecu is defective.
    P0254 is a problem with the rotor position of the pump - maximum flow.
    Apr 2009
    he wrote its JTD, that's bosch edc15, but it might be mistake.
    d.zio is it 223A6.000 or 182B9.000 engine code?
    Those errors are more common to Epic as oldford wrote, it's 1.9D.
    WHAT HAVE I TO CHECK FOR THIS???LUCAS IS THE SYSTEM.....
    SORRY ABOUT THE MISTAKE OF JTD.....LUCAS SYSTEM
    Apr 2009
    well this is how you go, because it's rotor position sensor, you have to change that sensor, or fix it, if you are ok with eeprom programming you have here software for fixing that problem and there's description in this thread too:
    http://www.digital-kaos.co.uk/forums...t-1-9d-218862/
    btw you don't have to remove injection pump.
    After doing that, car will most probably work, as for this other error, it could be anything, from wires to ECU.
    and yes P1603 might just disappear as you fix rotor position sensor.
    I CHECKED THIS A LOT OF TIME BEFORE......HAS PASS....DO YOU HAVE PASS PLEASE????
    Apr 2009
    i have just seen that he removed software.
    you dont need this pdf file that you probably downloaded.
    this is my original eeprom from 93c46 inside rotor
    Apr 2009
    here it is, hope it works.
    the car with this file dont start......i put again back the original and start but not accelarate....i went the car to someone who repair pumps,he looked it and told that the rotor sensor is defective......
    anyway thanks to all for your opinions and your help.....
    Sep 2016
    Romania
    i have the sdame problem , could you help me ? pls ...
    https://mega.nz/#!sVRzUKjB!x81QPEr2CHWfgDSOXP_XuZUVGTcmaI8CPMqQGac zlbo
    BEST OFF ...
