Page 1 of 2 12 LastLast
Results 1 to 15 of 29
    DK Veteran m3vuv's Avatar
    Mar 2010
    woodhall-spa lincs
    Default 2004 1.9 dcdi vauxall vivaro van
    hi all got this van in it starts them cuts out,eventualy it will start and run but few about ten seconds is realy sluggish to rev,its like its air in the system but im not 100% sure on this,its had a new fuel filter and there is no sign of any leaks on the fuel side of things,have these got a neutral switch on these ?,any help welcome on this,cheers Paul.
    Liteace's Avatar
    Mar 2009
    On a rock
    Did this all start happening after the fuel filter was changed ?
    DK Veteran Larue's Avatar
    Jan 2010
    Somerset, UK
    Any fault codes? All OK with rail pressure?
    Could be problem with EGR or air mass sensor.
    Meat-Head's Avatar
    one of them, jobs.
    Get your wallt out, extract ?100 - give the costmer ?10 - tell them to fopok off, donate rest to DK - really WILL be money well spent.
    Top Poster + richy_rich's Avatar
    Sep 2010
    I'd go with Larue's suggestions to start with, from the info you've given they sound likely culprits.
    May 2009
    meaty's right :-)............could be anything with out more info
    Mar 2010
    woodhall-spa lincs
    no fault codes coming up,once its going it runs ok!
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    answer Liteace
    Meat-Head's Avatar
    Quote Originally Posted by smirnoff_rules View Post
    answer Liteace
    No, you answer with your favorite anwser - pretend it's a Zafira Diesel.
    Feb 2010
    Without error codes youre suffed. Many elecyrical isses also cause similar. Look for chafed wiring behind thermoplungers, behind engine under airbox and check good contacts on large blue plug and smaller black one in main fuse/relay box.
  11. #11
    Sep 2009
    Ireland
    In 04 it could have an electric pump in the tank, has it got a hand primer beside the filter? If there is no primer there's an electric pump. Make sure its working. They will run without it but hard started.
    Ronan
  12. #12
    Mar 2010
    woodhall-spa lincs
    it has a hand primer,i did wonder about a pre pump.the van was fine untill one morning it was a bastard to staet and its been the same ever since,its just as tho its pulling air!
  13. #13
    May 2009
    pump up the handprimer and see if it starts better!
  14. #14
    Mar 2010
    woodhall-spa lincs
    ive tried that.it makes no difference,it starts first turn but cuts out strait away,on about the tenth try if you hold it flat out it will slowly rev after about 10 seconds then its fine untill you stop it and leave it for a few mins then its the same againe!
  15. #15
    Jan 2010
    Somerset, UK
    Quote Originally Posted by m3vuv View Post
    Had one the with same symptoms couple days ago.Turned out leaking safety valve in fuel rail. It's located on the end of fuel rail and there is a leakback pipe on top. There should be no fuel at all coming out from rail under cranking or running. If there is fuel coming out from that pipe then replace valve.
    As you haven't mentioned which engine management system it is i assume that is EDC15C...
