Results 1 to 7 of 7
    koziolek's Avatar
    Feb 2010
    Under the car
    Default 2007 e90 used dme coding
    I need to replace dme module
    is it posible to use one from scrub yard and if yes whats the procedure to make it work?
    smokey08's Avatar
    Mar 2010
    Essex, UK
    Yes should be ok to use secondhand one. What engine is in the car?
    koziolek's Avatar
    Feb 2010
    Under the car
    can You tell me more how to do it ?
    to make engine start
    Jan 2010
    E90 engine had alot of different engines and management systems...... Any way its not doable with regular diagnosis tools.
    peko's Avatar
    Jan 2010
    can you read eeprom flash and mpc from original ecu ?
    smokey08's Avatar
    Mar 2010
    Essex, UK
    Quote Originally Posted by koziolek View Post
    Only if you can tell me what engine the car has in it or what ecu is fitted.
    dimitar's Avatar
    Listen to smokey , he is the BMW guru
    50w Soldering Iron
    Chisel
    Sometimes Hammer
