Results 1 to 3 of 3
    busaman's Avatar
    suffolk uk
    Default 2001 saxo vtr lambda faults
    m.7.4.4 ecu
    po134 oxygen sensor
    p0135 upstream heating command
    p1327 ignition integrated phase detection
    replaced sensor
    swapped ecu, checked wirng for continuty between sensor and ecu, all ok
    downstream goes active upstream stuck on .44v
    7.31sec@203.3mph
    P0134 (No activity) and P0135 are probably linked.
    The heater for the sensor doesn't work.
    That may be a fuse, wiring, the sensor or even the ecu.
    P1327 is a problem with the coil. The coil provides the camshaft signal. Usually this means a new coil.
    Meat-Head's Avatar
    Quote Originally Posted by oldford View Post
    Back you up on that one.
    If the costomer is Polish - tell him he needs to try some new "Candles"
    If the costomer is Inglish, tell him he needs to try new "SPARK PLUGS"
    Meat
