Results 1 to 3 of 3
    Default g540 programmer and 28f512
    i recently bought a g540 programmer and i have the following problem
    i am trying to program a tms28f512 but i allways get programming error
    i can read and delete the chip but i can not write it (i can only write a blank file with ff , only then is says programing ok)
    i have tried several ic`s with the same result.
    i can write other eproms with no problem with the same programmer
    any help is apreciated
    thank you
    are you sure that the eprom is ok?
    Seems like your programmer not sending Vpp +12v to pin 1 during programming. Monitor for this voltage and hitting 'write'
