Results 1 to 4 of 4
    Dec 2010
    Default Kangoo 1.5 dCi 80 EGR off
    I have problems with EGR system and whant to disable it.
    Does anyone know how to disable EGR on this file ?
    I couldn't find EGR related maps.
    DK Veteran avtonega's Avatar
    EU
    I have some EGR off solution on my pc....
    Dec 2010
    Quote Originally Posted by avtonega View Post
    The problem is that the map you changed on this file is at a value of 8000 on the file I read from the car. So or this car of mine has been modified by anyother or the way of getting the EGR system disabled should be another.
    Thanks for your help
    Dec 2010
    I found other original files with same EGR map at a value of 8000, so my file is ok and not modified.
    I'll try to do some tests after fix injectors fault :-(
