Results 1 to 3 of 3
    Unhappy Openbox Signal problems
    Open box problems
    Basically switch on openbox works fine after about 5 minutes comes up with no signal, if I remove the sat cable from the box and reconnect starts to work again.
    I have changed LMB and sat cable, also tried 2 other openboxes with the same results! If I try at a different location all works fine! Really stuck on this any ideas
    Is it a quad lnb by any chance?
    Hi, The new one I put on is a quad yes the old one I took off is a duel
