Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: usb programmer
    Apr 2010
    Default usb programmer
    someone know this programmer? SOP8 Serial Eeprom universal device programmer | Minitools Product
    it is good for eeprom?
    Feb 2011
    Im not sure about the programmer, but their online catalogue looks pretty impressive.
    Member paddyp's Avatar
    Aug 2009
    Hibernia
    Looks bloody expensive for something that can only do serial eeproms.
    USB SPI FLASH EEPROM PROGRAMMER STANDARD BIOS FLASHER | eBay
    DK Veteran almeida's Avatar
    Feb 2010
    is much better to buy a upa serial programmer
    and the price is almost the same, and is a very good tool
    Apr 2010
    only 80 euro
    Feb 2010
    for 80? you buy a clone and for 120? you buy a original and work 100% clone work 75%
    smokey08's Avatar
    Mar 2010
    Essex, UK
    I think you would be better off buying a pcmcia>parallel converter, seeprog and a test clip. I have seeprog and it is an excellent programmer.
    Once you have brought all the leads for the different eeprom familys the programmer you are looking at works out very expensive.
    Apr 2010
    any programmer you need to buy clips no?
    by the way what clips i need for basic eeprom programming?
    thanks for help
    Nov 2009
    Quote Originally Posted by totalkey View Post
    only 80 euro
    i need it can u get or arrange for me
    Feb 2011
    thanks for help
    You cannot clip onto most eeproms, they need to be removed. Even good quality clips wear out and don't last too long anyway.
  11. #11
    Feb 2010
    Quote Originally Posted by workdamnyou View Post
    Sod clips. Most are shite that have too strong pressure anyway and end up popping off. As you re required to hold the thing in place anyway just buy the push on spring loaded type. Worth the extra and dont wear out and youll have fewer problems accessing the eep if theres another component soldered beside it.
  12. #12
    DK Veteran gtmech's Avatar
    Jul 2010
    Hell
    learn how to solder and start the job the proper way it should be done, im not being sarcastic either
  13. #13
    Apr 2010
    For mobile service i think is ok
  14. #14
    Apr 2010
    Just order from them
    Quote Originally Posted by nokwueze View Post
  15. #15
    Aug 2009
    Hibernia
    Let us know what vendor is and product id it has and what controller it uses, I bet its almost identical to the usbasp tiny.
