Peugeot 406 hdi copying maps.
Results 1 to 11 of 11
    Finland
    Default Peugeot 406 hdi copying maps.
    I'm complete noob in altering ecu software, i have 2 peugeot 406 hdi 110's the other has software modified by "specialist" and other is standard, i want to copy the modified maps to unmodified, how can i do this, the ecu hw & sw numbers differs a bit. Can someone explain how to copy only modifications or even do that for me :/ i checked these files with winols and they seems to have maps in same places if i understand correctly. I did read the ecus with galetto.
    Modified is:
    hw: 0281010363
    sw: 353049
    Original is:
    hw: 0281010248
    sw: 359169
    All help is a appreciated.
    benci1982's Avatar
    Aug 2009
    Slovakia :((
    Quote Originally Posted by plagu View Post
    Modified is:
    hw: 0281010363
    sw: 353049
    Original is:
    hw: 0281010248
    sw: 359169
    if this was a specialist who modified this sw:353049, did not touch him very!!!!!!
    I helped you, press thanks button
    Finland
    You think it's bad? What's done wrong in it?
    Atleast it seems much more powerfull than std.
    Finland
    Any one has any experiences on these files? are they any good?
    http://www.obdcar.com/powertuning/re...bosch,soft_169
    Top Poster + richy_rich's Avatar
    Sep 2010
    I'm going to guess no and no.
    Finland
    well if i'll buy that can someone check if it's any good? it's not that expensive...
    Feb 2010
    I hold you copied the map on another file as you requested
    not later than on the map and if done well or badly
    Finland
    i will test asap and post result.
    Default peo
    how many money do you save compared too pay for a good file
    Finland
    Quote Originally Posted by Alpinesport View Post
    The tuned map supposed to be good, and no one has said that what's wrong with it. The map costed 480eur few years back, so i think it's worth testing on other car also. I'm not going to pay another 480eur remap for 1000eur car, and then can't even tell if it's "proper" remap or not...
    it's pain in ass to find good remappers
  11. #11
    Default peo
    where do you live a what tool do you have
    it is possible to get files for 200
  12. The Following User Says Thank You to Alpinesport For This Useful Post:
