Hi, well you're almost right, it's actually Enigma1 it runs, not Enigma2. Here is the info we have been given:
The Protek server uses a softcam called Procam latest version is 0.16.
The unit it is fairly simple to setup for Protek use and those of you with Dreambox experience should have no problem.
2 Files need to be copied to var/tuxbox/config which is addon server.xml and procamd_ID this is basicly just a notepad file where you would copy and paste an ID which the supplier/dealer could supply and is very similar to uploading an ID to a Protek or it is also possible this could be pre-installed and the end user would simply press the blue button select addonserver and my server and download Procamd.
Hope this helps, although think we have decided not to go with these at the moment to be honest, we'll be looking at continuing to offer the existing Protek/NanoXX 9600IP instead and possibly an offer on the Technomate TM-500 to cover the entry level Linux receiver side of things.
