Hello!
Who knows the solution for chip tuning bmw 530d f10?
Hello!
use edc17 boot only way
Powergate does do BMW EDC17CP02 OBD without tp
fgtech can do it . Boot mode only.
You have to remove the PCB from the case this is very very
Tricky
Boot mode, with the boot pin on the reverse.
The boot pin may also be found on the usual side, I have seen people mention something about this, but haven't seen it confirmed
EDC17CP45 Tprot10 unit can not be done even in boot mode.
KESS and Optican do not make these ecu
You not right. I told you Galeta can do it. And Quality clones also. /But not tested on it./
T-boot & x17 also support on latest 4.6g version,
BMW EDC17CP45 + CP46 TP8/10 boot loader only
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
Hello
The question was about the edc17 from the new F models, not E models.
NO legal tool can do the F model edc17 at the moment. And shurely no clone!
greetings,
filecloud
Filecloud I respect your opinion. And maybe you absolutely right, but why you so sure about clone tools? Do you test it?
I have original tools and clone also and I cant tell you for sure that is quality ( same like original) clone cant do it. I not have F version on my desk yet . But E is Ok.
No one tool possible for the moment to tun the F series.
We use kessv2 with tricore, Ktag, new galletto, Byteshooter etc.
And over 5 client waiting :-)
Best regards
Hi.
This ECU is supported for K-TAG.
http://www.alientech-to.it/dox/KTag_Vehicles.pdf
