Results 1 to 10 of 10
    Jan 2009
    Question Question regarding manual satellite scan
    Hi there,
    I have a DM7025 and I'd like to update the feeds on one sat.
    When you do a manual satellite scan, you have the possibility to decide what is to do with existing services (Clear before scan):
    This is the clarification I found:
    Clear before scan:
    a) ?yes" means remove all services and transponders for this sat position / all selected sat positions
    b) "no? means hold all services and transponders for this sat position / all selected sat positions this resets all old new found flags (incremental scan)
    c) "yes (keep feeds) means the same as a) but hold all feed services/transponders
    I would need just a quick explanation about these 3 options, like when to use a), b) or c)
    In my case just now, I want to find the new transponders and remove the old ones. Should I choose option a) or c)?
    How I understand it is:
    a) Everything is deleted, and all will be seen as new after the scan
    b) Everything is kept, so after the scan I will probably have many channels in double ??
    c) --- I don?t really understand this one. Please explain!
    An other question about scanning, when you do a scan on a single transponder. There is an option ?Network scan: yes/no?.
    What is it? From what I remember, with Yes, the scan will find more channels, but I don?t know why/how.
    Thanks in advance!
    /Sunset
    Administrator
    Devilfish's Avatar
    Feb 2008
    Not sure about the first part of your post as I don't have a 7025, that's the first I've heard of that option.
    Regarding the network search option, if this is ticked, it will look at the NIT table for transponders with other channels in and scan them too. Usually you need to scan the default frequency on that symbol rate to be able to access the NIT table...but I'm not an expert at that shit so not 100% sure.
    V.I.P. Member westkill's Avatar
    May 2008
    if you scroll right on single transponder scan and it should show single sat scan
    chose the one you want and scan
    dm800-s=1.1 m triax motorised dish=titanium twin lnb
    DIGITAL KAOS BEST SITE ON THE NET
    please use the thanks button if someone has helped
    Jan 2009
    Quote Originally Posted by Devilfish View Post
    That's correct, I found the same answer. Thanks!
    Quote Originally Posted by westkill
    Yep, I know. The "Clear before scan" option is available when you do a single sat scan.
    I tested with option c) and it remove some "non-working/not-found" channels and added the new ones. So I think it's the option to go with for an update.
    Rgds.
    /Sunset
    DM 7025 - HD 80 Go
    Image: LT - The Fifth Campaign
    Junior Member stavo's Avatar
    Jul 2008
    Default RE config settings for dm 7025+ motor setup
    could some kind sole tell me please what the settings are so that i can set up my dm for a motorised dish i am using latest ep v4 image been trying for 2 days and cant seem to sort it i want to set it up with usals i have my lon &lat details but cant find in the menu where to put them any help please as my head is very close to banging off the wall
    much thanks stavo
    May 2008
    goto menu>setup>service searching>tuner configeration>chose tuner select tuner a >scroll right on cofigeration mode to advanced
    then under neath that it says satellite if you can scroll left or right you will see each sat
    mine is
    configeration>advanced
    satellite>28.2
    voltagemode>polorization
    tonemode>band
    use usals for sat>yes
    lnb>lnb1
    diseqc mode>1.2
    toneburst>none
    fast diseqc>no
    sequence repeat>no
    comand order>commited tone burst
    uncomited dieqc comand>none
    diseqc repeats>none
    longitude>
    lattitude>
    usals>yes
    then scroll right to next sat say 19.2
    then scroll down to lnb then scroll right and it will activate every thing automatically from your first sat your long ,lat and every thing else
    then press ok to activate all sat and it will exit automatically
    hope this helps
    Jul 2008
    thanks westkill will have ago at it when i get home from work will keep you posted
    Jul 2008
    not working for m8 followed tut to the t ~~~~ it i will let my tm drive the motor thsnks for the responce anyway
    stavo
    Feb 2009
    Default Multiboot recommendation *Help*
    I have a DM 7020s and wanting to back up my current working image then set up multi booting of two or mor images.
    I have a 300GIG HDD install with nothing on it yet.
    What is the recommended software to use that work with 7020?
    Thanks,
    V.I.P. Member despdan's Avatar
    Midlands Ireland
    hi
    google BarryAllen easy to use multibooting
