Results 1 to 8 of 8
    DK Veteran Bann32's Avatar
    Oct 2011
    Northwest
    Default Not connecting to internet
    When I boot my Dm800 se I am getting the following error message -
    NTP Check not possible.
    Network status: Unreachable
    I am using the following image -
    BACKUP-dm800se-2012-02-10-sim2-SSL-84b
    I know that the NTP is to check the date or time and I am assuming that my box can't access the internet? How do I fix this?
    DK Veteran potrobber's Avatar
    N Ireland
    have you went to network settings and clicked dhcp then restart box there is also a network test in there aswell all these settings would be manualy setup when a image is put on and you start your box for the first time
    why did you choose someones backup image?
    Oct 2011
    Northwest
    To be honest with you, it was this thread
     http://www.digital-kaos.co.uk/forums/f211/dm800se-clone-best-image-226997/index18.html
    Ill see if I can find the network settings section and check that out, thanks for your reply
    N Ireland
    if you do a factory reset it should also ask you to input all setup details
    backup images are where someone,s set up a image then loaded it here to download but there network settings would not be the same
    to check network setting is
    menu/setup/system/network/adaptor settings
    Oct 2011
    Northwest
    Yeah found it mate, thanks
    I just made the error then of choosing to update all software
    Oct 2011
    Northwest
    EDITED
    I believe I have installed CCAM, which directory would I find or not (as the case maybe), the ccam.cfg
    N Ireland
    it will be in the etc file double click etc and scroll down it should be there
    N Ireland
    m8 pm sent
