Results 1 to 11 of 11
    Jun 2011
    Question cccam switch pluggin
    Hello
    Can anybody snuggest a good cccam switch
    preferably for use with V3..
    Thanx
    Tobbyno
    May 2012
    is there a cccam switch plugin for Gemini 5.1 image?
    DK Veteran Rodbouy's Avatar
    Here you go mate.
    CccamSwitch.rar
    ftp the yellow extracted to usr/lib/enigma2/python/plugins/extensions
    Once you reboot, goto the plugin menu and press the cccam switch, now ftp to etc and you will see 6 you cfg files you can switch from.
    May 2012
    It works on gemini 5.1!!! Thanks !!!
    Jul 2012
    tanx for your help
    Aug 2011
    Liverpool
    Hi Rodbouy
    With ref to post 3 above I have been searching for one of these cccam switches for ages.
    I have one on my other DM800HD which has Dream Elite image on it and a plugin for switching between cccam config files.
    On my DM800HD pro I have a Nemesis image and want to have a cccam switcher on this, will the above work on this image aswell
    Many thanks in advance for reply
    Aug 2011
    Liverpool
    Default cccam switcher
    Thanks for reply Rodbouy, works OK with my "Nemesis DM800 Sim2 SSL84b image" after inputing it as you stated, now happy that I can change sea lions if they go down without having to switch on computer and use DCC
    Thanks again, only been 12 months trying to get this done on prievous images.
    Oct 2010
    South Manchester
    Quote Originally Posted by Rodbouy View Post
    Here you go mate.
    CccamSwitch.rar
    Hi mate,
    Can I ask what image you are running the pluggin on?
    Wondering if the pluggin is compatible with:
    Dream Elite 3.0 DM800HD-ramiMAHER #ssl84b
    Cheers.
    Oct 2012
    It didn't work on BlackPole image, any idea to solve the issue ?
    Oct 2010
    South Manchester
    Quote Originally Posted by tombutler View Post
    Hi mate,
    Cheers.
    I'll answer my own question as it may be useful for others to know that the above pluggin works just fine on the Dream Elite V3.0 image.
    TSPanel also allows you to switch config files. I was using this for a short while.
    Going in to the option with TSPanel to switch a short while back it listed the two config files. However neither of them were ticked. Usually one is and it's a simple case of highlighting the other, pressing "OK" to move the tick and then press "Activate". The box constantly green screened when attempting to tick box a config file. Fortunately the above pluggin saved the day.
    Dec 2012
    Default does this work on build 521
