EDC 17 checksum
Results 1 to 7 of 7
Thread: EDC 17 checksum
    DK Veteran danielm's Avatar
    19
    Default EDC 17 checksum
    I need to calculate the checksum in the EDC17.
    Is a WV 110hp passat
    What program is it calculated?
    regards
    NASTASE's Avatar
    ROMANIA
    99
    Winols.
    You have checksum.
    Real engines don't need forced induction
    Who needs a turbo when you have a stupidly quick naturally aspirated engine?
    19
    Will not start
    BR
    ecutuners's Avatar
    Apr 2011
    United Kingdom
    270
    Cracked winols does not work on edc17 use original sw or tool with checksum when writing
    Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
    ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
    EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
    DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
    Professional Engine Software Development
    netherlands
    Quote Originally Posted by ecutuners View Post
    i have original winols, chechked the file above and must say checksumm is oke..
    What does diagnostic say?
    Dec 2010
    15
    Hello
    Problem is, that the original file is NOT original. It has been treated with ecusafe which does not work on those ecus.
    Checksum of both files is not correct.
    greetings,
    filecloud
    19
    Yes treated with ecusafe
    BR
