Results 1 to 3 of 3
    Default citroen xsara picasso, fault codes
    Hello all got another Citroen in, lucky me, its a 2003 1.8 petrol 6fz, light on with two codes, p1110 air flow inconsistent and p1161 throttle position copy, scoped throttle unit and its making its mins and max, with pedal operated, cleared fault been on 20 mile test and no faults, thinking throttle body but unsure, no codes have re appeared, anybody had same codes and had a conclusive fix ?
    Cheers
    Ted
    DK Veteran Larue's Avatar
    Somerset, UK
    If wires between throttle and ECU are OK then next throttle body.
    Thanks, yeah that what I thought, As it's playing ball at the minute every test comes out ok, I bet the customer manages about a mile before it plays up again.
    Ted
