    Top Poster 03ahmads's Avatar
    Jun 2011
    Default Ram detection issues
    First of all my pc spec is as follows:
    Gigabyte p67a-ud4-b3 mobo
    I5 2500K processor
    8gb corsair 1600mhz ram
    850w psu
    My ram is split in 4 2gb sticks, was having issues booting into windows after upgrading bios to latest version therefore tried booting with one stick of ram, turned out the ram was not the issue. Now when I replaced the ram it is not detected, tried adding a stick at a time and each in different slots but no luck, only 2gb of ram is detected. I know it's not detected as it shows in bios, also windows wont load, it says there may have been a recent hardware change (the ram) at my wits end here, any help will be greatly appreciated.
    DK Veteran R_J's Avatar
    Jan 2009
    Canada
    Try reseting the bios
    You may clear the CMOS values by removing the battery:
    1. Turn off your computer and unplug the power cord.
    2. Gently remove the battery from the battery holder and wait for one minute. (Or use a metal object like a screwdriver to touch the positive and negative terminals of the battery holder, making them short for 5 seconds.)
    3. Replace the battery.
    4. Plug in the power cord and restart your computer.
    Jun 2011
    Thanks for the advise, I did try this yesterday, didn't seem to do anything, I left the battery out for around 5mins, it doesn't look like the cmos values were cleared - the profiles which I saved were still there, I think I need to reseat the jumper, once I find out what it looks like
    Jun 2011
    Problem solved! It was me being a dimwit! I wasn't pushing the ram in properly Obviously shows it's my first time installing ram!
    V.I.P. Member lagerland's Avatar
    Sep 2010
    Right ere Right now.......
    Quote Originally Posted by 03ahmads View Post
    You live and learn m8 it clicks when seated correctly..........
    I am not sure you realise that what you heard is not what i meant !
    Jan 2009
    Canada
