Results 1 to 4 of 4
    Top Poster + powertdi's Avatar
    Jan 2011
    Russia
    Default Hot start fix on FORD Cmax
    I have a problem car here Ford Cmax 1.6TDCI. Problem is in Hot start. Car do not start when Temp above 60 degrees . I cant understand is it a problem with hotstart or not? Is it possible to fix it?
    Sep 2009
    Don't think that this help you
    I think you need check rail pressure at start
    MAGPro2 x17, MPPSv12, FGTech, BDM100, BMW OPS, MB Star, Ford IDS, Lexia, Clip, Opel OPCOM, VCDS, VAS5054, Openport 2.0, XprogM, etc...
    Jan 2011
    Russia
    Serj but why is cold start is good? Maybe a fuel temperature sensor? When car cant start temperature is about 45 C" , rail pressure 270 bar .
    bobolin4o's Avatar
    Apr 2010
    Bulgaria, V. Tarnovo
    1EA268 is your map.
    NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
    If your PM box is full, clean it right now...
    Otherwise, your requested file will be deleted... for ever!
