hacka247 (26th March, 2014)
isit possible to delete some of the category's if so how can i do it on a skybox f3?
The recording problems have been fixed, it was because I removed the scrambled flags from the channels. If you mean you literally can't record have you definitely got a suitable external drive plugged in? If so try updating your firmware.
Channel list upgrades should only effect the channels, only firmware upgrades effect your cccam details etc.
You can't talk about that here, google cccamm server.
I think you can only do that from the computer with a channel editor.
BTW I'll be updating this week.
can any one tell me how i can get a radio chanel list ,put a chanel list on but took my radio list off,thanksnew to this
How to backup the factory firmware of Skybox F3.
Finally getting the Grips off things install your list Cheers mate![]()
Cheers AJ.
know anyone who does a multisat list (for footy)?
There's a few about but all way out of date I think, if you only want it for the footy you could just scan the transponders that those channels are on.
KingOfSat 13e
KingOfSat 19.2e
Cheers mate,
that's the next thing I want to learn - how to make channel lists.
If I get it sorted I'll post on here...
Hi AJ,
Used your list to build myself a channel list for the Scottish region, although had to do this on my box. Have you got a channel list editor to recommend I could use? I'm on an openbox S11.
Looking to get the Olympic HD channels added onto the list but not sure about doing it by manually scanning on the box incase it just overwrites it and/or doesn't let me add it onto the current channel list.
It's either that or if you're interested in upkeeping a Scottish list and I can send you it.
Cheers
hi aj is their a radio chanel list to have,i updated my chanel list,wich is great thanks but i now have no radio list ,could you please help me cheers,and keep up the good work,thanks
Cheers mate, been using your channel list for a bit now and I had lost my nat geo +1 and a few others and Just checked now and you have fixed that, appreciate it mate thanks your doing a brilliant job here.
Would it not be easier to update to my latest list & just move the Scottish channels rather than keeping your list & manually updating? If you only want a few channels then you should just scan those transponders & they'll be added to the end of your current list, you can find out the transponder info at KingOfSat LINK
SetEditHD100 is the best editor but isn't free unlike AliEditor which is & should do everything you need anyway. Check the attached file.
I'll update the radio channels some time this week.
