Results 1 to 5 of 5
    May 2011
    Default New graphics card causing freeze at start up
    I bought a new Sapphire Radeon 6870 HD 1GB card to for my PC today. I have registered to your site so you should be able to find my details.
    I had a Nvidia 9600GT previously, I removed the drivers & installed the new card, When I install the drivers for the Radeon & reboot my machine it freezes at the starting windows page. If I then reboot in safe mode & remove the drivers & restart the PC boots up. Can you please help me as to where i'm going wrong. I been reading on this it could be there are conflicting drivers causing the issue.
    My operating system is Windows 7 64 Bit Ultimate. MY power supply is 600W. My motherboard is a Asus P5K SE/EPU.
    Can you give me a idiots guide to resolve this issue.
    Any help is appreciated
    thankz
    ICe
    Sep 2008
    not too well up on that but are your drivers supported for 64 or 32,xp or windows 7?
    Jan 2009
    basics checked?
    cables checked no faulty wiring
    or anything pluged during
    bootup
    ok
    remove drivers fro your card for the moment
    clean your registry
    ccleaner
    link is here
    CCleaner - Optimization and Cleaning - Free Download
    then reinstall your drivers
    now shut it down
    open your case
    check your ram
    make sure there all sound pull them check them one at a time so you know they work.
    check your psu *do you have another one to compare to*
    sometimes they can cause problems for cards depending on their load
    when idle and full and sometimes it happens also when the psu is not
    a quality build.
    check your hard drive
    has there been any noises from your hard drive or heat?
    check for overheating sometimes they get to the temps of like 60 when they turn off but i doubt thats the case
    its problery your psu i think
    hope you get it fixed
    Top Poster rg66's Avatar
    Dec 2011
    Entebbe, Uganda
    If you had no issues with your previous card and it works ok without the drivers then it doesn't sound like a hardware issue. Go to Sapphires' website and see if there are newer drivers for that card and try them.
    If it is a driver conflict read this. Get Driver Sweeper here, the downloads at the posted link are corrupted.
    May 2011
    Quote Originally Posted by rg66 View Post
    thanks for all your advise, removed all drivers then re-installed window. All running smooth, new cards wicked!! 74250 on 3d mark 03, is that good? happy days!!
