Results 1 to 2 of 2
    Dec 2010
    Default Glow plug Citroen HDI
    Citroen Xsara Picasso 1.6HDI and 2.0HDI.
    1.6 has separate 4 lines from relay to glow plugs. 2.0 hdi has 1 common line from relay to plugs.
    What voltage (12V or 5V) is used to power the plugs in both models ? I've seen in 2.0 5V on plugs and I'm not sure is it correct ?
    how does the "diagnose line" in relay work ? Is it only logical state that means "glow plugs are ok" ?
    Does 1.6 good working relay "clicks" when tested from Lexia ? I can't hear anything. In 2.0 it is clear sound of relay.
    Thanks !
    Top Poster + richy_rich's Avatar
    Sep 2010
    Should be 12V in both models mate.
