Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Belfast, NI
    I dont think theyre the hardest tbh, 8bit is more fun or even delco etc where theres not much info. I learned on old 8bit delco petrols years ago, I didnt even realise the wealth of info on american forums about them either then old diesels 8bit and mechanical, then edc15 with a few hints was alot easier to get my head around.
    Its a tad expensive for parts for this car if anything goes wrong though so maybe not best that way.......
  2. #17
    Belfast, NI
    Heres a map pack for win ols, it should have everything you need, now you must log your car with opcom to see whats going on, then dig out the alfa gt 170hp file from the net and see what the manufacturer done to increase power. Be careful and log log log read read read.
  3. #18
    Belfast, NI
    Just re read this thread and noticed you said this is 150bhp, are you sure? The values look a bit low for 150bhp, did you read it through obd? Some tools miss the right map range.......I'll check a cdti 150 file Ive read and used tomorrow I'm on my home computer atm.....
  4. #19
    Yes it's 1.9 cdti 150 bhp.
  5. #20
    Belfast, NI
    Could you get a read with bdm? Theres an excel file in there with a map list btw as well as the map pack, open the file with winols then go to import/export in the project menu, select map pack (.kp) and import my .kp file.
  6. #21
    Belfast, NI
    10 people did NOT find that ^^ helpful
  7. #22
    The only file i have was read with a original powergate master v2. My mate has a kess2 think that will do a full read.
