Hi, tried it M8, wont play,maybe a plug in is needed?
Just had the second box delivered today and this is an update.
If you are ordering the box from Estonia,it comes with an old firmware (V 1.15),which doesnt have the Cam config or Upgrade by network options.When it arrives you will need to update the firmware by USB. Link in post 58.Once the new firmware V 1.17B4 is installed,scan the sats and you will be ablew to upgrade online,put in your cam config and view U tube etc.
Ali editor tool for channels.
latest fw,
Re: AB Cryptobox 400HD- PATCH fw Re: AB-PATCH Cryptobox 400HD firmware
::::::::::::::::::::::::::::: 1.17B4 ::::::::::::::::::::::::::::: ::::::::::::::::::::::::::::: ::::::::::::::::: List of changes 1.17B4 ::::::::::::
! ! ! ! ! SW THIS MUST BE UPDATED AS ALLCODE! ! ! ! !
1, correction for YouPxxx
2, added Dutch language
3, WiFi deep standby reboot fix for 400HDmini
Httpserver port changed to: 80, AB used httpserver
V 1.17b4 patch.
Yes Youpxxx is on.
I posted a link in post 58 .Thanks Dreamuser for putting the file here. I have installed this in my new box. Re; Recording one channel and watching another.I think you can only watch a FTA channel and record another Fta channel.It seems not to work with scrambeled channels.If you are recording a scrambeled and want to change to another channel,it will stop recording.Can someone try this and confirm please.
Single tuner box = you can only record and watch channels from same transponder simultaneously.
Dual tuner box = you can record and watch channels from two different transponders,simultaneously.
Cheers
