Page 1 of 3 123 LastLast
Results 1 to 15 of 40
    DK Veteran gadgetfiend's Avatar
    Aug 2008
    Default Flashing the EX7000 HD with USB
    Flashing The EX7000HD using USB
    1. Download the required firmware
    2. Unzip and copy it to your usb pen or equivalent, ensure filename is (flash.tbn).
    3. Insert it into the usb slot and switch power off then back on at the rear switch.
    3. box will reboot, open the flash file extract it to its memory and install it automatically.
    4. Once flashed its a peice of cake select your desired settings, scan then enjoy.
    simplicity....
    GF
    Nov 2008
    if only ...............!
    Nov 2008
    Default ANYBODY NEAR WALTON ON THAMES WANT CASH ?
    I HAVE A SPLITTING HEADACHE TRYING TO GET MY BRAND NEW EUROVOX 7000 HD TO WORK....I CANNOT SEEM TO SCAN THE CHANNELS ?
    CASH PAID FOR WORKING INSTALLATION
    CHEERS,
    PETE
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    So do i with all your cyber shouting . Calm down m8 you will get sorted.Whats the problem why isn't it scanning ? You have to explain clearly, no one can see the problem your having. Have you read through ALL the posts on the forum. Chances are someone else will have had the same problem before.
    Jul 2008
    follow the instructions u got with the damn thing not hard,also make sure before u do that to put firmware on usb,plug it in,then switch on the box before u do anything else
    Feb 2009
    Quote Originally Posted by gadgetfiend View Post
    simplicity....
    GF
    How can I install firmware for my new eurovox ex7000 hd+
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    You can start by posting an intro in the introductions section telling us a bit about yourself. THen you could go to the relevant forum and read a little about what your looking for and use the search button to search further. Then you will probably know how to flash your box. Not as easy as being spoon fed i know, but think of the satisfaction of doing it by helping yourself
    Followed instructions re-booted and yes update found and installed. Still not getting all the available channels.The only thing I do not understand is the last bit in the instructions. Is there something else that I need to do when it says, " Once flashed its a peice of cake select your desired settings, scan then enjoy"? I don't seem to be getting the enjoy bit yet.
    I know the satisfaction of rummiging around here and yes this box is a piece of cake compared to the earlier boxes just I feel I am missing something?
    To continue from my previous post. Is there something I need to change in the boxes settings? Thanks Steve
    Junior Member waspish's Avatar
    Jan 2009
    Manchester
    Quote Originally Posted by Stevejeep View Post
    what channels are you missing? you also have to do first channel search from the main cable wire that comes into your house.
    Hi, It seems now that after doing another full scan that I have all channels.
    What I now have is the task of editing the channels. I downloaded from somewhere on the forum a channel editing software. Do you know if this is to be uploaded to the box the same way as the fw and do I rename the file the same way i.e. name it as flash.tbn? Or is it something that is to be used on the pc somehow? Have not done as yet in case I screw it up. Thanks for the previous reply by the way.
    Jan 2009
    Glad to see you have now got your channels, now for the "not so fun bit". The editor is appaling, you are best doing it via the menu system on the box, long winded but does work to a point. There are loads of threads on the forum about the poor Fav menu and editing features on the box. New firware will hopefully sort it out
  13. #13
    Jul 2008
    any ideas when new firmware is due? really hope they fix the channel change slowness
  14. #14
    Looks like this evening will be spent sorting the list out then, Thanks for the reply though. Steve
  15. #15
    Mar 2009
    Hi, im thinking of buying a eurovox 7000 and ive been reading the threads to learn form other people the teething troubles that they encountered, to allow me to set it up sucessfully. Im having problems clicking the firmware update link. I t wont authorise me, please help!
