Results 1 to 14 of 14
    Bratislava,Slovakia
    Default Mercedes W203 ezs calculation
    Hi friends.
    I have a problem.....The key does not rotate W203 EZS.
    number : 203 545 06 08
    MCU 1J35D Motorola.
    Read ETL programmer.
    Please repair dump and generated key dump....and upload....
    Very thanks.
    DK Veteran technobox's Avatar
    cyprus
    mate how to read etl i try but always error pls help
    DK Veteran lashkar97's Avatar
    Jan 2012
    Indonesia
    if u not success read 1j35D by ETL
    than tri with select
    2j74y
    4j74y
    Jan 2012
    Indonesia
    cpu data is ok
    renew key and write key again
    keys are here
    cyprus
    i try mate when 100% done replay count 1 to 100 always linking
    pls help
    never lost anythink only change ...
    Bratislava,Slovakia
    Technobox.....
    Original or China clone ETL programmer?
    Clone repair....around the solder (picture).
    Check solder.....
    Jan 2012
    Indonesia
    than ur soldering is not 100% check all pins
    one by one with ohm meter
    Default Read 1J35D problem
    Quote Originally Posted by technobox View Post
    Your message is usually cannot read 1J35D from ETL , the problem is your clone ETL ( from China make) is bad quality , i use it to read 2J , 4J , 1J35D and never not work , I think that u need to buy a new one quality and you can enjoy it
    Member detayoto's Avatar
    Sep 2010
    hello my friend. I am dealing with the same problem. I have written and read by etl tool does not work. Let us help each other
    makura's Avatar
    Had that problem til i got my self an Orange 5 programmer,now i can read any chip presented to me with no problems.
    DK Veteran germanml's Avatar
    Sep 2011
    spain
    hello, I have the same problem with Vito 2007, the doesn't turn or rotate, which 1L02M should I read?? please
    thanks in advance
    Sep 2011
    spain
    Here the Dump, PLease some help
  13. #13
    DK Veteran JOHNCICY's Avatar
    Mar 2011
    EAST AFRICA
    Quote Originally Posted by germanml View Post
    Your dump is ok...check the key if its ok and power on the steering lock.
  14. #14
    Sep 2011
    spain
    thanks a lot jhoncicy,
    I will check the power
