Results 1 to 5 of 5
    Default Remote control not responding, works when i use the web browser remote. help pleaseTY
    Hi, im having trouble with my dm800, the remote has stopped working and wont respond at all, however the standby button works but only if i press down on it hard. (no other button works- from time to time remote starts working but not for long)
    also note the remote control through me web browser works perfectly and responds instantly.
    i read a post on another forum that the problem may lie with the infra-red sensor not working properly and may need replacing.
    can anyone shed some light as to what may be causing this problem and how to rectify the problem. Thank you kaisar.
    Jul 2008
    you can apparently check ir sensor on remote using mobile phone, never tried it myself but seen threads on it. If its your problem, easily rectified, change ir sensor or buy new remote
    Quote Originally Posted by smoggie View Post
    thanks for replying, any chance on posting link to the thread, and how do i test the ir sensor with my mobile phone?
    and where can i buy the replacement sensor from?
    Quote Originally Posted by kaisar1 View Post
    Hi mate. put the phone in camera mode, press the remote and focus the camera at the sensor, if it is working you will see the red beam on the phone screen. Check it with a known working remote 1st, so you see that it works.
    Good luck
    thank mate, the remote wasnt working. opened the remote and re-aligned the rubber buttons, now i can see the infrared light.
