Results 1 to 5 of 5
    Default opel corsa c 1.7DTH egr problem
    is posible remove egr in this car i have a problem whith the ecu i think that is the + of the ecu because i put other - but the same problem , if i cant remove the egr i have to lock for a used ecu and change for the used one. i put the file fo this ecu thank you
    Default corsa
    sorry the file
    Feb 2012
    Yes, it is possible, if you want, then we can discuss
    say to me th problem is in the ecu , the ecu is broken
    Lithuania
    If problem in EGR, you can use EGR emulator
