Results 1 to 15 of 17
    Mosc
    Default Toyota Techstream 7.00.020 VIM select -does not display devices
    Hello, I have problem with software Techstream Toyota 7,00,020, .
    The program installed correctly, the drivers are installed appropriate. I tried on another computer and everything works fine, which may be the reason???
    Please see print screen with my problem.
    Last edited by hjulet; 18th March, 2012 at 09:39 PM. Reason: I also installed the older version on your computer and continue the same. Please help.
    Ashraf6119's Avatar
    UK
    Is the Software been Activated..............
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Mosc
    Yes, software is activated.
    I did everything the same as on the second computer is running - displays several devices to choose from.
    Ashraf6119's Avatar
    UK
    If the Software is Activated than how come it don't show any days of validity on your screen print.........
    Try un-installing the software and re-install it again and see if that helps..............
    Thanks Ash
    hi
    where can i get a copy? Thanks.
    Mosc
    I already tried re-install (re-install software and drivers). Nothing helps. As discussed earlier, on the other computer shows the devices. I think that maybe somewhere in the Windows registry are stored some old settings .. ? I had a techstream already installed and working well then uninstalled and installed version 7.00.020 and no longer shows the devices.
    Ashraf6119's Avatar
    UK
    Quote Originally Posted by randomwalk101 View Post
    hi
    TTFULLCRACK700020.zip
    Thanks Ash
    Ash,
    Is that cracked version, which does not require registration?
    Mosc
    I inserted the print screen that shows the program working properly.
    Why does my computer list is empty and nothing is displayed?
    Techstream uninstalled several times and drivers, and nothing helps, any time not on the list of devices
    Password to Unzip files?
    If you are running xp you might need to upgrade net framework to the latest version
    Can i get a password fot techstream?
  13. #13
    Apr 2012
    Saudi Arabia
    Quote Originally Posted by hjulet View Post
    hey Bro you have to format your computer and install again .
    i had this problem before , or try to install VMware lode XP and install techstream
  14. #14
    Ash, can i get the password ?
  15. #15
    USA
