Results 1 to 15 of 16
    DK Veteran mburu's Avatar
    Sep 2010
    Default pp2000 software keygen not able to generate key....
    Hi mates, have installed Peugeot planet office software(pp2000 23.25) n it's running well but if try to generate key(keygen pp2000 22) it gives me error code11..
    help please.:
    Jun 2009
    There are 2 keygens for PP2000 one works ok the other doesn't.
    drakov's Avatar
    Aug 2008
    for software version you need to put PP2000-23
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
    Sep 2010
    Quote Originally Posted by drakov View Post
    will you post the keygen(pp2000 23.25) for me coz am stuck
    Sep 2010
    Quote Originally Posted by bochen View Post
    post for me the good keygen...for free
    gyapi11's Avatar
    Aug 2011
    Hungary
    Quote Originally Posted by mburu View Post
    PP2000-23 without25
    gyapi11's Avatar
    Aug 2011
    Hungary
    Are you exempt from the no posting keygens rule DK has??????
    Sep 2010
    Quote Originally Posted by gyapi11 View Post
    Sample+Keygen
    I was not able to download the keygen it keeps on debugging error msg archive not supported.. can you generate key for me..
    code: CH0001
    software packages: PP2000-23.25
    PC IDENTIFIER: 155070234
    REQUEST CODE: 2853
    Sep 2010
    PP2000-23 without25
    post it i try please...
    try A0BE-9515-6F76-56B0-4E3D-94BB-35B7-B0A8
    I got this instead
    FFD39F9F1CADFC6BF54FF100E3F0EE39
    But you may need to generate another RQ if you for any reason disconnected before using our codes as the RQ changes everytime
    Sent from iPhone 4S
    gyapi11's Avatar
    Aug 2011
    Hungary
    code: CH0001
    REQUEST CODE: 2853
    write it like this and it is going to work
    code: CH0001
    REQUEST CODE: 2853
    A0BE95156F7656B04E3D94BB35B7B0A8
  13. #13
    long ago didn't use it so maybe i'm wrong. but back to read the 'readme' it says a dash sign needs to be put between each four of the codes hence i put them above.
  14. #14
    Sep 2010
    Quote Originally Posted by sogaro View Post
    I got this instead
    i tried still (error code 11) the activation code is not valid. please post 4 me keygen..
  15. #15
    Sep 2010
    code: CH0001
    REQUEST CODE: 2853
    have managed to change instruction key and it has worked.....
