Results 1 to 8 of 8
    alotmentman
    Guest
    Default can i flash dreambox 500swith dcc
    help can i flash dreambox 500s with dcc and idiots guide need thanks
    Senior Member shankill2012's Avatar
    ULSTER
    Yes but make sure you use dcc for enigma 1 boxes, check the stickies for the tutorial on flashing by telnet and all other tutorials which may come in handy.
    Mar 2012
    use dreamup is good
    May 2008
    hi
    follow this tut
    Digital Kaos > Cable > Cable Dreambox ? Guide: Flash and Backup an Image via Telnet
    doing the ftp and telnet parts in dcc
    Using dcc to flash image to DM500s
    1 ftp image to tmp on dreambox (make sure you call the image in tmp backup.img )
    2 go to telnet part of dcc and type or paste
    cd /tmp && eraseall /dev/mtd/3 && cp backup.img /dev/mtd/3 && reboot
    3 wait till box has flashed with new image
    hope this may help
    May 2012
    Default account dreambox
    hallo...saya ade dreambox 500....macamana nak setting untuk tengok siaran astro.....
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Sila cuba post dalam Bahasa Inggeris dan youll mendapat sambutan yang lebih baik .... atau lain menggunakan google menterjemah.
    Freck
    Jun 2012
    Might be stupid question, but what does dcc stands for?
    I have an old dreambox, inside i could see that it is using inadyn settings, dcc is not using indyn at all?
    Nov 2010
    Quote Originally Posted by irwinhor View Post
    Dreambox control centre = dcc
