Results 1 to 14 of 14
Thread: usb loadergx
    Mar 2012
    northern ireland
    Default usb loadergx
    hi im new to all this
    installed hbc on my wii now trying to install usb loadergx .once i get it installed i get a message saying usb loadergx requires
    cios222 or 245-250 can any body help me please
    thanks lactose123.
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Welcome to DK.
    You will have to do some reading then.
    You don't say what Wii version your using?
    Install all the wads in d2x v7 Final and IOS236 with MMM.
    Have you done a NAND backup and installed PriiLoader 0.7?
    You could post a sysCheck as instructed?
    Keith
    2010 Golf GTD (170)
    Mar 2012
    northern ireland
    thanks keith for getting back to me.
    im running 4.3e.
    sysCheck v1.6.2 by Erik Spyder
    Region: PAL
    The system menu v514 is running under IOS58 (rev 6176)
    Hollywood v0x11
    Console ID: 74189466
    Boot2 v4
    Found 173 titles
    Found 31 IOS on this console
    Found 15 IOS Stubs on this console
    Aug 2010
    England
    Quote Originally Posted by lactose123 View Post
    im running 4.3e.
    Region: PAL
    Hollywood v0x11
    Boot2 v4
    Found 173 titles
    Where have you had that sysCheck from as its v1.6.2? I gave you the link to my upload sysCheck. Please post the full report not the first 8 lines. Those few lines don't tell us what Wii version your using even though you've said 4.3 and it should tell us if you have PriiLoader 0.7 installed as suggested.
    Keith
    2010 Golf GTD (170)
    Mar 2012
    northern ireland
    sysCheck v2.1.0b11 by Double_A and R2-D2199
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Homebrew Channel 1.0.0 running on IOS58
    Hollywood v0x11
    Boot2 v4
    Found 174 titles.
    Found 46 IOS on this console. 15 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 256): Stub
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 256): Stub
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 2816): Stub
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 5120): Stub
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 6400): Stub
    IOS61 (rev 5662): No Patches
    IOS70 (rev 6912): Stub
    IOS80 (rev 6944): No Patches
    IOS222 (rev 65280): Stub
    IOS223 (rev 65280): Stub
    IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug ES Identify NAND Access
    IOS249[37] (rev 21006 Info: d2x-v6): Trucha Bug NAND Access USB 2.0
    IOS250 (rev 65280): Stub
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2012/03/23.
    V.I.P. Member ck-ok's Avatar
    nottingham
    Region: PAL
    Hollywood v0x11
    Boot2 v4
    Found 174 titles.
    BC v6
    MIOS v10
    what tutorial did you follow?
    do what keith told you in the 2nd post should get you up and running
    Aug 2010
    England
    I see you have d2x-v6 installed you maybe better with dx2 v7.0.
    I see you don't have PriiLoader installed install it from my link to block online and disc updates?
    Keith
    2010 Golf GTD (170)
    Mar 2012
    northern ireland
    Region: PAL
    Priilaoder installed
    Hollywood v0x11
    Boot2 v4
    Found 179 titles.
    Found 51 IOS on this console. 14 of them are stub.
    IOS245[37] (rev 21007 Info: d2x-v7final): Trucha Bug NAND Access USB 2.0
    IOS246[38] (rev 21007 Info: d2x-v7final): Trucha Bug ES Identify NAND Access
    IOS247[53] (rev 21007 Info: d2x-v7final): Trucha Bug NAND Access USB 2.0
    IOS248[55] (rev 21007 Info: d2x-v7final): Trucha Bug NAND Access USB 2.0
    IOS249[56] (rev 21007 Info: d2x-v7final): Trucha Bug NAND Access USB 2.0
    IOS250[57] (rev 21007 Info: d2x-v7final): Trucha Bug NAND Access USB 2.0
    IOS251[58] (rev 21007 Info: d2x-v7final): Trucha Bug NAND Access USB 2.0
    BC v6
    MIOS v10
    Report generated on 2012/03/24.
    how does this look now is there anything else i need to do
    how do you get gx on the wii main channels.
    thanks lactose.
    Aug 2010
    England
    That look ok and USB Loader GX works from HBC? You still have 14 stubs but if it works ok then don't worry. I see you have PriiLoader installed now and I assume you have enabled the online and disc updates? Its a bit confusing when you have to enable something to block it. I got rid of the 'A' safety prompt as well on mine.
    To add the USB Loader GX channel to the Wii menu you need to install Forwarder from there USB Loader GX-UNEO_Forwarder_4_0_AHBPROT.wad. Put it in the wad folder on the SD card and install it with MMM.
    Happy game playing.
    You can click the Thanks under the useful comments that have helped you.
    Keith
    2010 Golf GTD (170)
    Mar 2012
    northern ireland
    thanks keith
    when i try to install forwarder its give message
    did not complete.
    Aug 2010
    England
    Thats strange just keep trying until its complete.
    I use a different USB Loader GX-UNEO_Forwarder.wad on mine if you want to Google it?
    I did upload USB_Loader_GX-UNEO_Forwarder.wad.zip last year for another user on here but the search facility on here is shocking I can't find it at the moment. It should have the paperclip on that thread but again that takes a lot of searching with my name Keithuk sorry.
    Keith
    2010 Golf GTD (170)
    Mar 2012
    northern ireland
    i got it working
    i forgot to load ios236 first.
  13. #13
    Aug 2010
    England
    Well that comes from not read the d2x v7.0 final link I posted. Though IOS236 shows up in the sysChecks you've done.
    I'm glad your up and running with USB Loader GX.
    Have you thought of trying CFG USB Loader and WiiFlow each USB Loader has different features you may find the others will work better for your needs.
    Keith
    2010 Golf GTD (170)
  14. #14
    happy_highlander's Avatar
    Aug 2010
    Remember d2x v8 final has been released, it won't make any difference for you keith as you don't use the emu nand function for game saves but other users may and will have problems using v7 with emu nand
