Results 1 to 15 of 15
    Mar 2012
    Angry problem with my wii on 4.3e
    Please help. i have softmodded my wii on 4.3e using indiana jones original adventures but i still cant play copyied discs on it, the screen keeps going black, i can play original games still, i have followed various tutorials and still nothin, is there a channel i need to install to play them, im currently trying to use neogamma 8 and this isnt any good , also the bootup in hbc isnt doing anything either,,, gggrrrrr. any ideas,
    Oct 2008
    Default wii backups
    you need a external hdd to play games the newer wii don't let you play backup disc
    Mar 2012
    Unhappy problem with wii...
    i do have an older wii but it is updated to 4.3e... i used to be able to play backup discs until the update but not now.... so does the new softmod only play via external harddrive them ?.. thanks for your time.
    Aug 2008
    i would like to know this too please.
    Oct 2008
    Default wii backups
    Quote Originally Posted by stueyb View Post
    how old is the wii did you update then soft mod it
    Aug 2008
    my wii is new and came with 4.3e on it.
    Oct 2008
    Quote Originally Posted by jewish View Post
    you will need to softmod using modmii as your wii will only play backups from a external hdd
    Aug 2008
    thank you for quick reply.
    so modmii will do it all?
    do i then just put the iso as is on to the externall drive?
    Oct 2008
    down load modmii answer the questions it asks and you will be able to do it all, its a very good program and now with letter bomb included you don't need a game disc to do a 4.3 wii
    Aug 2008
    Thank you very much. Will try it this weekend.
    V.I.P. Member ck-ok's Avatar
    nottingham
    sounds like you dont have neogamma on your sd card
    try this Digital Kaos - Downloads - Neogamma R9beta56 with forwarder and mmm
    i am assuming you fully modded the wii not just installed the homebrew channel?
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Quote Originally Posted by ck-ok View Post
    I'm not sure CK as he says
    He can have the Neogamma channel if he wants that but he says Neogamma doesn't work.
    He also says he's on 4.3 but we don't know what it was before he softmodded. He should type in the Wii serial number into Wii Drive Chip Database
    Keith
    2010 Golf GTD (170)
  13. #13
    Aug 2008
    Quote Originally Posted by jimbojimjay View Post
    Just found out the Wii is actually a 2006 model.
    I bought it 2nd hand but its the first one i`ve ever bought.
    The firmware shows 4.3e in the settings.
    So what softmod do i need to install to play back up discs?
    Thanks.
  14. #14
    Oct 2008
    Thanks.
    still use modmii and if its an old model you will be able to play backup disc but i would set it up for hdd works a lot better and saves on discs
  15. #15
    Aug 2010
    England
    Yes 2006 Wii's should be able to play burnt discs but as Jimbo says your better of installing the wads needed to use the USB Players and get a powered external hard drive to add the games onto its going to be cheaper in the long run.
    Keith
    2010 Golf GTD (170)
