if you have the first backup with bdm rewrite and start!!!
if dont have car not start.. maybe immo corrupted
when use obd flasher must do this procedure ..
Download Suzuki_Key_Code.JPG from Sendspace.com - send big files the easy way
regards
hi today i read a grand vitara 1.9 did whith ecu edc16 with gallletto original
hw 0281012569 and sw 1037377494 i had the same ecu read whith bdm 100 . why the galletto dont have the same check sum ? Can gallletto read and write by obd or i need use bdm whith this ecu. i tried to write by obd and write and rewrite all times but the car dont star now whith the original and the mod file . i think that the problem is because the inyector decode i tried to write the inyector code but i cant write.but when i see the checksum of the file the galleto is diferent of the original file that i have.tomorow i try to write the file by bdm
regards
professional chiptuning and electronic car repair...four-DynoRace_ wheel_ dynamometer
Instructions for FG tech and Vitara should be in the documents.
PatricioPanama (1st January, 2019)
i have backup by obd but dont have back up by bdm but if i change by obd it change only external eprom no change mpc and eprom 95xxx that it is where have the immo ,if i put the original file that i have this file the car should star.no????
some body can check if the orginal checksum of this car is A40D. the euc is 569 7.494 .
i had same problem with original cmdflash,immo is out...only bdm on this car.
and the solution only virigin file or clone the same ecu and immo box and new key?????
I don't know mine was repair by suzuki diagnostic...
no change the ecu?, i think that i need only put the file and recode inyector
problem is immo ...
solvend the problem is that galletto read bad file and write bad file by obd i need to write by bdm and all ok again dont eraser immo
