Look in 16 bit at the start of the maps for 26000.
Factor .25 = 6500 rpm
Thanks a lot
Now one more question
Who knows where the range for the VANOS in the MS41 and this Bosch ECU
Nobody knows what?
No,
it is a simple on or off control, so it is not like a Vanos map you will see in MS42/43 or MSS50+
Maybe a single line.
It is a single line, 1 for on and 1 for off.
can you tell me where this is?
Look for 2 lines 8x1. X axle=RPM ,Z axle=Engine Load
There is a slide difference in these 2 because of the hysteresis.
can you tell me the address where to look
can someone please tell me the mechanism that I set the max. white values (see) for ignition, injection, lambda?
Hello
Can someone help me with rev limiter, i want to set it to 7500rpm.
Car bmw 2.8i MS42. Thanks
borysgo2 this should do it. 7520RPM rev limit
Regards,
Mark
can someone put rev limiter to 7500
thank you
