Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 71
  1. #46
    Canker_Canison's Avatar
    12th Level of Hell
    Quote Originally Posted by asimh View Post
    after resetting p50, should i clean waste ink tank. thank your prompt reply
    That is up to you. If you don't do anything, the printer will eventually start to leak over your desk.
    Changing the pads isn't the easiest job. But connecting a longer pipe is very easy.
    How's your Russian?
    http://sroogle.ru/youtube.php?v=E9Vs7V_uEmI
    Canker
    "Animal, vegetable or mineral... I'll do anything, to anything, with anything"
    - The Baby Eating Bishop of Bath & Wells
    [COLOR=Green]
  2. #47
    Jan 2013
    Default p50 pain
    Hi, I'm new here. Been jumping through hoops like a circus poodle trying to get a reset utility for my printers. I have 4 p50's printing cd's meant for distribution for a corporate client. 2 of these printers are now inisting on getting serviced. The ssc thing i used for my older printers is obsolete, can you please help out?
    Efpe
  3. #48
    Junior Member ttt123's Avatar
    Thanx for this Canker.I`ve used the WIC utility before but it does not cater for the P50. i just stumbled across your programme while having a general browse on here.It works perfectly.
    Thankyou.
    ttt.
  4. #49
    Feb 2013
    do you have to buy a key to reset?
  5. #50
    Feb 2013
    how is the reset done?
  6. #51
    Feb 2013
    Default p50 t50
    do p50 and t50 use the same reset
  7. #52
    Feb 2013
    is this still working?
  8. #53
    Feb 2013
    Hi!
    How many time I can use this, before I actualy have to replace the Ink pad.
    Thanks!
  9. #54
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Quote Originally Posted by madaoaie View Post
    Hi!
    Thanks!
    Its there for a reason as in time the waste ink will overflow.
    Best thing to do is check your printer and try and mop up the excess ink with some tissues.
    Waste ink collects in an area with a sponge on most printers.
    That way you wont have an inky carpet.
    Andy.
  10. #55
    Mar 2013
    Can this be used for a artisan 50 ?
  11. #56
    12th Level of Hell
    Quote Originally Posted by kampuni kubwa View Post
    Yes
    Quote Originally Posted by ramafoto View Post
    Yes
    Hi!
    Thanks!
    Once. I would advise bypassing the waste pipe.
    Small square cover on the back of the printer. Think it's held in place by a single screw. Clear pipe inside can be pulled away from a connector & extended to a collection tank of your choosing.
    Try googling 'epson P50 waste ink mod'
    Canker
    [COLOR=Green]
  12. #57
    Mar 2013
    Default Epson P50
    If i don't charnge that waste pad, could be a problem on long run?
  13. #58
    Mar 2013
    Quote Originally Posted by viokara View Post
    Depends on how much you have invested in you're printer. I paid 200$ for P50 with CISS, and printed more than 5 liters of ink, so, it already paid off, i just need to use is until it snaps definetively.
    Sorry for the crapy english.
  14. #59
    Mar 2013
    I'm going to download this and try it for the Epson Artisan 800. If this is the wrong program for the 800, anyone know where I can find the right one?
  15. #60
    12th Level of Hell
    Quote Originally Posted by ventaak View Post
    I left this link to Epson on another post.
    Canker
    [COLOR=Green]
  16. The Following User Says Thank You to Canker_Canison For This Useful Post:
    HIGH VOLTAGE (18th May, 2013)
