Results 1 to 4 of 4
Threaded View
  1. #4
    Jun 2012
    Default Seagate USB 3.0, 2TB External HDD on Vu+ Duo with Blackhole
    Quote Originally Posted by potrobber View Post
    m8 when you say its not patched yet do you mean its a clone? which in that case it would have been very simple to put in your title vu duo clone which seems to be a problem with some people not saying at the start of there thread which box they have
    now to your problem what have you done to set your hard drive up in settings on your duo
    some info might help us
    when you try to initialize it what happens?
    My one is also not working. It is recognized when I get to initializing. After initializing I get either error or everything goes well and end up without any message. When I check it in HDD section, it says HDD doesn't exist. I struggle with setting it up for 2 days now. I try mounting it but it doesn't work. I have done it properly. Also, tried to format it to EXT4, EXT3, EXT2 ... Tried also making more smaller partitions.
