Results 1 to 9 of 9
    Member topepi's Avatar
    EU
    Default BMW E90 CAS2 XPROG
    Hello
    I have problem with CAS2 BMW e90 2006
    read by xprog-m (
    ELDB) MC9S12DG256 2K79x . i reset value km and the car no start
    Maybe cas is dead or maybe is my flash is corrupted
    i need full flash for this cas please :
    61.35 - 6 981 416
    CAS 2 ( E8x/E9x )
    MCV-0.0.0 / FSV-6.2.6 / OSV-3.3.0 / RTV-0.0.0 /
    HW.-03 / SW.-27.1 / COD.-05 / Diag.-INDEX-6A0
    SIEMENS VDO : 5WK4 9412LBF
    i post eeprom and flash if you can check it ?
    Thanks in advance
  2. The Following User Says Thank You to topepi For This Useful Post:
    nanux (30th September, 2013)
  3. #2
    mitext's Avatar
    Feb 2011
    I think the problem is in the eeprom. there ACC?
    EU
    yes ACC and ignition work
    micromax's Avatar
    South Poland
    try disconnect car battery for 5 min.i have same cas dump. here you have.
    EU
    Default resolved
    I resolved my problem .
    the problem are on car sensor .
    thanks for help
    joubliss's Avatar
    Far away
    ur dump look fine.
    VIN : WBAVC11060VE08006
    Odo : 273123 km
    Mechanical code: 0386
    and u have 3 keys used. 2 remotes and 1 pcf7936.
    *No Help For Leechers
    Press THANKS button if my post was Helpful
    All my Files are Protected with Password
  8. The Following User Says Thank You to joubliss For This Useful Post:
    Hayssam1 (18th March, 2016)
  9. #7
    peko's Avatar
    Quote Originally Posted by topepi View Post
    thanks for help
    which sensor ?
  10. #8
    EU
    Default sensor clutch
    sensor or transmitter
    on pedal clutch , needed press on it for start your engine . i see the connection are bad and broken , previously have people disassemble it bad work .
  11. #9
    Top Poster nanux's Avatar
    Ireland
    Hi , Corrupted flash while reading eeprom. 4 post flash give error for start/stop button. Flash from 1 post work perfect. Same symbols on the CAS sticker.
    Thanks lads.
