Page 1 of 4 1234 LastLast
Results 1 to 15 of 58
    Oct 2010
    Smile DAS + Xentry 01.2012 install in one step
    Here is a solution to install DAS + Xentry 01.2012 in one step!
    Take mr. zolookas guide 2h,after finished prepare.bat rename in registry the value BASICXP to COMPACT4
    Then you must change the harddiskserialnumber with HardDiskSerialNumberChanger.exe to the following Serials:
    C: 5008-DCB7
    D: 0C26-B56C
    E: B0AA-2E4C
    F: 9CB7-53D7
    Then copy the DAS + Xentry install in one step.exe to
    C:\Documents and Settings \ STAR \ Start Menu \ Programs \ Startup
    Then restart your PC!
    Now you must put a new License for DAS and Xentry in your startkeymanager.
    That?s all
    Now you can start the Installation from the original DAS DVD.
    DK Veteran wsc's Avatar
    GR
    great mate i will test it and report
    Smart car engineer ,
    Newbie jpinheiro's Avatar
    Porto alegre, Brazil
    Is this procedure for a fresh install ?
    Tks and rgds.
    Feb 2011
    Works perfect thank you
    Oct 2010
    Hello, you can use this procedure for fresh and old installation.
    regards
    butchers
    This point is not clear to me:
    "Then copy the DAS + Xentry install in one step.exe to
    C:\Documents and Settings \ STAR \ Start Menu \ Programs \ Startup"
    I do not find "Start Menu \ Programs \ Startup" on "C:\Documents and Settings \ STAR ".
    As always, tks and rgds.
    Oct 2010
    Quote Originally Posted by jpinheiro View Post
    Hello, you must have start menu! On your Desktop in the left down site is "Start"
    If you click on Start---> all programs---> startup
    make on startup with your mouse a right click and click on open.
    Now you can copy the DAS + Xentry install in one step.exe into this folder.
    good luck!
    This matter is solved.
    At end of intallation I got erroe -5011 0X80040707.
    Just DAS inatalled.
    Rgds.
    Oct 2010
    Just DAS inatalled.
    Rgds.
    Hello you must read this thread for your error:
    http://www.digital-kaos.co.uk/forums...2011-a-233670/
    There is a fix for error 5011.
    good luck!
    Aug 2011
    there is an error appears on Xentry opening dose one have any clue
    Wink
    Quote Originally Posted by amrafia View Post
    try with this fix
    DK Veteran yuuki's Avatar
    Nov 2010
    Japan
    Can you save the Xentry key?
  13. #13
    Aug 2011
    yes i can save the key and give me save succefully
  14. #14
    Nov 2010
    Japan
    What is your App Id?
  15. #15
    GR
    Just open the SDNC.....
