    DK Veteran fandm's Avatar
    next door to fred
    Default Launch diagun fault codes
    Hi is there a list that shows what the fault codes are that the diagun displays they only seem tobe 2 number faults
    most of the time.
    DK Veteran ghostridersa's Avatar
    Nov 2011
    I would also like to know if there is a list.
    Quote Originally Posted by fandm View Post
    most of the time.
    Top Poster grimmer's Avatar
    Dec 2010
    norfolk uk
    most of the time.
    If if scanning using the individual manufacturers diagnostics the diagun will read in their fault code number.
    If ur unsure of any you can just rescan the car in obd2 mode, the fault then come up as a p-code with the same or similar description.
    Or autodata mostly tells you the manufactures fault codes and meanings
    Car Diagnostics
    Nov 2010
    I use Diagun more then 2 year and always it give nice result
    But you must check correct car or system
    borysgo2's Avatar
    The best one I had was on Fiesta automatic gearbox, fault for driver's pretensionner circuit :P
    Some parameters in live data are equally acurate as fault codes .....
    miha99's Avatar
    EU
    Maybe you need to pay for some serious update.
