Sadly it didn't work.
I could not match immo - id, keys and ecu, odometer still showed 999999 and fuel gauge showed wrong value
I tried both procedures:
http://wiki.ross-tech.com/wiki/index...ument_Cluster)
Ross-Tech: VCDS: Immobilizer 3 Instrument Cluster Swapping
For last one CAN gateway was not working at all.
I tried 5-number pin. as I have no idea how to get or generate 7-number pin.
Hi!
1st: You don't have a can gateway in your car
2nd: You don't have to generate a 7-digit-skc. Just start with a 0 and then enter the 4 digits of your cars skc
Procedure - how Ross-Tech explains - works perfect. Please try again and post the results.
Do you have:
* Login/SKC from your car?
* Login/SKC from your dashboard?
* VCDS HEX+CAN interface?
Cheers, d2mike
I did everything like explained here:
http://wiki.ross-tech.com/wiki/index...rument_Cluster)
It did not work, I have already swapped some immo3 clusters w/o any problems.
Not my car, I can't check it right now.
Who can share another working dump for this cluster?
Hi, what is differences between RB4 and RB8?
I'm really not a cluster guy that's why so stupid questions.
No problem:
Actually the only difference should be the SW version in the NEC mcu and the resulting menu navigation in the DIS. RB8 can be IMMO3 and IMMO4c. The attached dump is RB8 with immoblizer generation 3, the same as your reference instrument cluster.
Try this RB8 dump. If it's not working, I'll send you a RB4 one.
Cheers, d2mike
It is in first post.
There is no def, odometer shows 999999 but vag k can sees original mileage. everything happened after flashing car with good galletto clone (fuse 15 removed).
