Results 1 to 8 of 8
    DK Veteran garry1312's Avatar
    Oct 2010
    Scotland/ Somerset
    Default FileZillla not working ET9200
    Cant ftp to the xtrend just receiving this status on filezilla:
    Error: Connection timed out
    Error: Could not connect to server
    Status: Selected port usually in use by a different protocol.
    Status: Connecting to 192.168.0.6:80..
    Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    Are you deliberately using port 80 for FTP, if not then that is your problem, FTP should be port 24
    Oct 2010
    Scotland/ Somerset
    Quote Originally Posted by Mjolinor View Post
    Still not working with port 24. Although I have always used port 80 and port 80 has always worked.
    Nov 2008
    my flash fxp is on port 21 for ftp use (just checked)
    Oct 2010
    Scotland/ Somerset
    same result with 21 as well I always use 80 be it with filezilla or Dreambox control center but its just not working with 80, 26 or 21
    digicon's Avatar
    Just a longshot here but you could have some form of corruption occurred on the image.
    Mar 2009
    has your boxes ip address somehow changed?
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    Yup, brain fade, should be 21 not 24.
    Assuming you have proved the IP to be 192.168.0.6 then you need to download NMAP and see what ports are open.
