    Mar 2012
    Default VAG K+ Commander 1.4 crash on MM Direct read
    Anyone able to get VAG K+ Commander 1.4 (China) to read Immobilizer III on an 2002 Audi TT?
    When I choose Immobilizer -> Margenti Marelli Direct it reads and I can hear the car making sounds like a servo is moving then the program crashes before it shows the login / PIN.
    I've tried Margenti Marelli Shadow 3 TT with no luck either. It doesn't crash, but it doesn't get the PIN.
    I've tried multiple computers using Windows XP and all of them crash right after it read Margenti Marelli Direct, what's the trick?
    smokey08's Avatar
    Essex, UK
    Post the dumps you have managed to read and we can try and extract the pin manually.
    Mar 2012
    Quote Originally Posted by toy4two View Post
    does it can read immobilizer?
    Mar 2012
    Quote Originally Posted by smokey08 View Post
    Here's the dump I read, thanks for helping me find the pin manually.
    Remove the .txt from the file name.
    Mar 2012
    that first attachment was done under INSTRUMENTCLUSTER in K+ Commander. Here is an bin done under ECU EEPROM Read in case that is the one you need.
    My car has an APR Stage 1 Tune (257hp 91octane US tune loaded on it) If that helps anyone. Engine type is AMU 225hp model.
    keygargoil's Avatar
    i cant open your files use win rar right click and add to archive then upload the files
