Results 1 to 15 of 16
    Apr 2011
    Spain
    Default Help to read ECU of Ford Focus.
    Hi all,
    I try to read ECU of Ford Focus 1.8TDCI year 2007 with interface Magpro with version 4.2 and I can`t, I don`t know why.
    I think that the connection between RJ45 and OBD connector missing one cable, I only have five cables:
    5-Signal ground
    6-Can high
    7-K-line
    14-Can low
    16-+12V
    and to connect with ford ecu is necesary protocol Ford SAE J1850
    pin 2-J1850 BUS+
    Ford OBD-II diagnostic interface pinout and wiring @ pinoutsguide.com
    Can someone check your interface to see if this cable is necesary and where is connect de cable at RJ45, please.
    Thanks.
    Russia, Kirov
    Magpro do not work with J1850 (PWM/VPW), only K or CAN ECU.
    Apr 2011
    Spain
    somebody know why I can?t read the ECU of Focus, if possible my Magpro is bad or is different ECU than SIS 202, also I try to read with flashtec but I can?t read.
    I think my magpro have a bad hardware because don?t work correctly don?t read data of the ECUs.
    Thanks.
    UK
    i would check the obd cable from magpro...some come with the can wires not connected,have you tried the magpro and done a read on a can read.
    Apr 2011
    Spain
    Quote Originally Posted by pablo1971 View Post
    I check the OBD cable the wires are connect correct but in the magpro I don`t know where go the wires.
    I don`t read more ECU with protocol CAN but if don`t work in Focus I think in more is dificult.
    UK
    Sorry for my ignorance,but is this a clone tool or original...
    i read somewhere on dk a member had problem reading a car on CAN,and when checked out the wires are not connect at 16 pin obd end....connect them and all is good.
    Apr 2011
    Spain
    Is a clone tool.
    5-Signal ground
    6-Can high
    7-K-line
    14-Can low
    16-+12V
    Missing some wire?
    Stanton's Avatar
    Dec 2010
    UK
    The answer has been given!! The tool does not support the Ford OBD protocol!
    Apr 2011
    Spain
    Quote Originally Posted by Stanton View Post
    Thanks.
    I thought this ECU use CAN protocol.
    Top Poster + powertdi's Avatar
    Jan 2011
    Russia
    I have same ECU today on Transit Conect. sid206. Can protocol you right. 2Mb flash.
    Galleto2 clone can do this job perfect.
    Ro
    Byteshooter geniune works with sid206
    furburger
    Guest
    Ford protocol use pin 2 &10 for their data lines but magpro2 don't have that protocol , only kessv2 or powergate have this at the moment I think ?
  13. #13
    Apr 2012
    I read ford mondeo 2.0TDCI/hdi 2009 years with magpro without problem,ecu sid 206! via can-bus,why many peoples think that ecu read/write J1850 (PWM/VPW) protocol,i think is for diagnosis wires bsi,airbag and etc..
  14. The Following User Says Thank You to AGS For This Useful Post:
    fadifadi (28th April, 2013)
  15. #14
    furburger
    Guest
    The vast majority use the ford specific protocol and pins 2/10 .. You only find a tiny coverage of ford on most tools- your '09mondeo is one of these 'exceptions.'. Try reading an '01 tddi or '05 tdci mondeo with Magpro
    Galleto 2 hoovered up every possible protocol he could copy when making Fg2 and added some original protocol ( crafter obd) but omitted ford
    BS made a specific separate tool ( crossfire ) to cover Ford..
    Ultimate copycat Magpro copied the ford masters Alientech but couldn't add ford in either V1 or V2
    Cmd won't answer questions about covering Ford in their' #1 'tool
    Not sure if it's something to do with 15v being needed to wake many ford ecu's but for sure powergate or kess v2 are only tools that have good ford coverage
  16. #15
    Jun 2012
    La Coru?a - Spain
    I just want to put here my two cents.
    My chinese clone FGTech (AKA galletto 2) have read and wrote perfectly via OBD a couple of EEC-V ford ecus.
    Both 1.8TDdi from year 2003. Both visteon. PWM.
    Don't know which pins it used, but worked.
    So FG2 at least in my case support FORD.
