Results 1 to 9 of 9
    DK Veteran markovojvodic's Avatar
    Oct 2010
    zagreb croatia
    Default B 180 CDI 2005 DPF off
    Hi guys im having big problems with making dpf off on this car - i made dpf off and disconnected lambda probe , mil isnt on , car is running quite good until you reach 80-130kmh and then it goes into limp mode
    DTC are :
    - P2359 - turbocharger pressure over limit
    - P2084 - DPF - flow control
    any idea what to do ?
    files are in attach
    vuno01's Avatar
    Europe
    check the vacuum hoses
    because if they leek you will have turbo pressure exceeded
    mislav88's Avatar
    Mar 2011
    is this file made by ES?
    Oct 2010
    zagreb croatia
    i will check only the problem is that car disnt had this problem before
    I am here: http://tapatalk.com/map.php?4vcgwb
    Oct 2010
    zagreb croatia
    No not ecusafe i bought this file from my suplier ..... not ecusafe i now its not working
    dyc's Avatar
    Quote Originally Posted by markovojvodic View Post
    did you solve your problem with dpf in this car?
    soundnavigator's Avatar
    Sep 2010
    This is the same file as ES 2.0 and not work.
    Best regards.
    All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
    Our database available for download 24/7 on EVC server for all legal WinOLS users
    [QUOTE=markovojvodic;1510975]No not ecusafe i bought this file from my suplier ..... not ecusafe i now its not working[/QUOTE
    Usually ES make this problem
    Oct 2010
    zagreb croatia
    yes finally solved with anither file problem
    was with a file
    I am here: http://tapatalk.com/map.php?23zuuv
