Results 1 to 11 of 11
    makura's Avatar
    Default TOYOTA HILUX KEY
    Hi guys
    Can some one pliz edit this key into this dump,its for a toyota hilux diesel,the car has no immo box so i want to match immo box with key and ecu.
    Key data 4D 67..92 AF 60 55 D3 05
    richard27's Avatar
    Aug 2011
    4C type tansponder you are using 93lc66
    ​information sharing
    makura's Avatar
    Quote Originally Posted by richard27 View Post
    Well if you look at the last key used i am sure its 4D,i even loaded the dump on to the TMPRO2 software and it say transponder to be written is TPX2.
    richard27's Avatar
    Aug 2011
    zedbull original 4c you know the file
    joubliss's Avatar
    Far away
    ur key added to the dump (immo). (Pass in Pm)
    Job
    *No Help For Leechers
    Press THANKS button if my post was Helpful
    All my Files are Protected with Password
    richard27's Avatar
    Aug 2011
    yes, as you know is very close to apologize for the zedbull 4c orji 4d67 (
    makura's Avatar
    Quote Originally Posted by joubliss View Post
    Job
    The dump is still the same m8,nothing has changed.Meaning the key was already matched?so my problem is now sync between immo and ecu,i cant do the pin 4 and 13 short thing,the obd plug only has 3 wires,B+,ground and the com line.
    Hi friend
    You need 4d67 page1 32
    Regard
    makura's Avatar
    Quote Originally Posted by immo_key View Post
    Hi friend
    Regard
    What about the ecu?does it need sync data to be matched or not on this car?
    keygargoil's Avatar
    Quote Originally Posted by makura View Post
    Hi guys
    here you go fella
    keygargoil's Avatar
    your key is already in the file
