    May 2008
    Default Viewing card crashes duo clone
    Just received vu+ duo clone from Aspleys, fast service by the way. Just discovered that if I use both card slots the box crashes? It's fine with one card in either slot but if a second card is entered it immediately crashes and won't restart until one card is removed.
    Anyone come across this before?
    V.I.P. Member dell_xps's Avatar
    Why do you need 2 cards it at once m8 ?
    Are you using any cam software ?
    May 2008
    Using a gamma card and a sky card with oscam. Either card in either slot is fine on its own but as soon as second card inserted the box locks up. Locks up half way through booting unless one card is removed. Very strange. Will have another play tomorrow with diffent cams .
    DK Veteran lincsat's Avatar
    Jun 2008
    Maybe it's the Gamma card conflicting with the Sky card, or something with your Oscam config. If all else fails, you could try an external Omnikey or similar for one or both of the cards and see if that works.
    digicon's Avatar
    I have 2 freesat Sly cards in mine and they have never crashed it had them in since day one of owning the Duo
    May 2008
    been having a play this morning.
    Having same problem with cccam on its own with these 2 cards together. BUT I also have a dutch freesat-type card and that together with the sky freesat card are fine in both oscam and cccam???
    Not too important as I can run my gamma in my old dm800 no problem, its just got me baffled though.
