Results 1 to 2 of 2
    Default Record one channel and watch another on 600C
    I've just got my 600C uand running on the Jade PLI image.
    Tried a few recordings, off the EPG and instant and all appears ok.
    By mistake I changed the channel whilst recording and it still continued to record the original channel, whilst I watched another!!
    Would I be corrrect in thinking that this is limited to the channels that are on the same transponder as the one being recorded.
    Also a small moan. When I go to watch a recording, if i hit the rewind button at the start it locks the Dreambox up completely ad I have to remove the plug to reboot it. Does anyone else have this problem. Using a WD 160GB HDD.
    Jun 2008
    Quote Originally Posted by bilbo1161 View Post
    Would I be corrrect in thinking that this is limited to the channels that are on the same transponder as the one being recorded..
    You would - if you scroll through the channels while recording, you'll only see the ones on the same transponder
    If you change to a channel on a different transponder, the recording will stop.
    Me too - but you quickly learn not to hit rewind at the start of a recording
