Quote Originally Posted by bilbo1161 View Post
Would I be corrrect in thinking that this is limited to the channels that are on the same transponder as the one being recorded..
You would - if you scroll through the channels while recording, you'll only see the ones on the same transponder
If you change to a channel on a different transponder, the recording will stop.
When I go to watch a recording, if i hit the rewind button at the start it locks the Dreambox up completely ad I have to remove the plug to reboot it. Does anyone else have this problem. Using a WD 160GB HDD.
Me too - but you quickly learn not to hit rewind at the start of a recording
